Diplomat ADP8101/2 integrated dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8101/2 integrated dishwasher
  • #15599
    WetSocks
    Hi, I have had a simular problem as posted by Bluejools last year. After clearing up the excess foam I have cleared the water and detergent from the dishwasher (good old turkey baister) and flushed with clean water but the machine now seems to be stuck in the wash part of the cycle. After filling with clean water from a jug the machine washes and never drains (left it running for 4 hours) – Any suggestions. Does the machine use the same pump for washing as draining ?
    Many thanks.
    #164222
    Re: Diplomat ADP8101/2 integrated dishwasher
    This is most likely a “no heat “problem – thermostat must click over at wash temperature to reactivate timer. Likely causes heater failure, stat failure, wiring failure, or safety tripped out.
    Awkward machine to try and work on – you may want to consider pro help – click the link below.
    Power off if investigating for yourself.
