DIPLOMAT ADP8102
  • #8981
    MARTINSKI
    HI ALL, FIRST TIME POSTER, GO EASY ON ME !!
    DISHWASHER JUST OVER 3 YEARS OLD. WASHER WOULDNT DRAIN AND NO HOT WATER. DOES THE WATER NEED TO REACH A CERTAIN TEMP. FOR THE TIMER TO MOVE ON TO THE NEXT CYCLE? TIMER STICKS AT ROUND ABOUT 12-13 ON THE TIMER CYCLE. HAVE TRIED RESETING IT WITH NO JOY. ANY HELP/ADVICE WOULD BE MOST APPRECIATED.
    REGARDS
    MARTINSKI. 🙄
    #131468
    Dave_Conway
    Re: DIPLOMAT ADP8102
    Yes, it needs to heat to the correct temperatre before the timer will advance.
    It sounds like the heater overload thermostat has cut out, they are manually resettable.
    Please ensure the plug is pulled beforehand though :zap:
    #131469
    MARTINSKI
    Thanks for the prompt reply Dave, cheers.
    Could you tell me where and how to reset the thermo. as this is all new to me, and yes I will pull the plug beforehand 😆 :zap:
    #131470
    Dave_Conway
    I can’t go in to specifics I’m afraid due to EU legislation.
    Neddless to say, it’s near the heater 😉
    #131471
    MARTINSKI
    Could you give hint i.e. is it accesible from inside or underneath washer?
    🙄 hope i`m not getting you in (hot water) over this 😆
    Great help so far
    Cheers Dave.
    #131472
    Small white box, red button, underneath. Power off……….
    The provisional flipper of
    MARTINSKI
    Cheers big boy 😉
    #131474
    Big boy? :rotfl: :rotl: . Penguins are not noted for their vertical triumphs!
    But, thanks.
    Power off first…….
    MARTINSKI
    :clown: Cheers !!!
    #131476
    MARTINSKI
    Right in about things now, does the small switch have two grey wires and is situated bottom right ?? with piece of polystyrene attached to the trip ??
    Thanks in advance
    Martin. 😛
    #131477
    MARTINSKI
    😥 Thought i had found heater overload thermo. but i dont think so going by your description.
    How close is it to the pump ?
    Cant find the red reset button, had bottom tray off , is it hidden by a cover ?
    Helllppp !! :haier:
    #131478
    Dave_Conway
    It’ll look something like that 😉
    #131479
    Hi guys,
    Can you tell me the colour coding on the wires so that i can pinpoint the reset button, all “clues” are most appreciated.
    I wont be defeated !!! :tup:
    Cheers
    Martin.
    #131480
    MARTINSKI
    Anyone know the wire colour coding for the thermo reset ??
    :worthy:
    Martinski.
