Diplomat ADP8102/1 not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8102/1 not emptying
  • #16928
    mizz_s
    my diplomat integrated dishwasher is not going into rinse mode or emptying ! It seems to be stuck slooshing round & round. I switched it off on the panel & at mains & took out plates etc. Left it for 10 mins I then turned the dial to rinse, plugged back in & switched on – but it went back into sloosh mode. The water is white and was warm (but not now)
    I have had a quick peek through the forums and seen that it’s probably caused by 3 in 1 dishwasher tabs, but is there is a way of getting it to empty or reset? e.g hold both buttons in for 10 seconds or something like that. I think it’s quite an old model.
    The machine was given to us by a relative who doesnt like dishwashers – its no longer under warrenty and there’s no manual. It’s been installed and fine for the last 6 months.
    cheers 🙂
    #172215
    Dave_Conway
    Re: Diplomat ADP8102/1 not emptying
    It’s stuck on the heat stage possibly, due to the overheat cut-out tripping (caused by overfoaming using 3-in-1 tabs ;))
    A pretty straightforward repair normally, check the repairs@ link below 😀
    If you do decide to look further yourself, power off :zap:
    #172216
    mizz_s
    Thank – you 🙂
