Diplomat ADP8102 – leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8102 – leaking
  • #36977
    splloydie
    I have the above dishwasher, bought from MFI in 2000 with a new kitchen. It has now started leaking from the bottom left handside of the door. The seal seems ok in that there is no obvious difference between either side. There was some limescale on the rubber seal but I have cleaned this off – and it still leaks! Any suggestions? Is it a common problem/fault?
    Thanks.
    #253029
    Re: Diplomat ADP8102 – leaking
    The “goalpost” door seal was modified at one point, with an “L” shaped piece of plastic added at the bottom. Also worth checking the bottom rotor for splits along the edges.
