Diplomat ADP8102 leaking from door
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8102 leaking from door
  • #51221
    splloydie
    My Diplomat ADP8102 started leaking from the bottom corners of the door yesterday. In the past, this has been because of a split in the lower rotor arm but it seems to be ok and is only a few months old.
    Any suggestions?
    #307297
    Re: Diplomat ADP8102 leaking from door
    Perished bottom door seal or a large build-up of crud? Door outer panel off to see properly.
    splloydie
    Thanks – but my wife spotted a hairline crack in the lower rotor arm, right on the tip of it, that I hadn’t spotted. I had a spare, swapped them over and no more leaks!
    Many thanks – I’ll keep an eye on the seal too.
