Re: DIPLOMAT ADP8112 LIGHTS 1 &5
In the known error codes under Smeg 😉
SMEG error codes….
Well it keeps coming up, so someones got to do it…….
E1 – 1st flashing, 5th lit – flood protection system activated.
E2 – 2nd flashing, 5th lit – safety pressure switch activated.
E3 – 1st, 2nd flashing, 5th lit – no heat in time allowed.
E4 – 3rd flashing, 5th lit – temperature sensor fault.
E5 – 1st, 3rd flashing, 5th lit – no fill.
E6 – 2nd, 3rd flashing, 5th lit – no drain in time allowed.
E7 – 1st, 2nd, 3rd flashing – flow meter detected when not fitted Very Happy – reset required.
E9 – same code as E1, so how you tell the difference is beyond me, but is a related fault to E1 + E2.
