Diplomat adp8132
  • #34459
    jcb208
    Hi have the above machine and the upper spray arm will not spin, yet when i open the door you can see lots of water coming out the jets.Have cleaned the arm and cant see any blockages.Any help please.Ps the bottem arm spins fine
    #242703
    Re: Diplomat adp8132
    Tip jets blocked is the usual problem.
    jcb208
    Im back with this same problem, cleaned jets and worked for a while but the top spray bar still refuses to spin most of the time .It will work now and again ,
    the dishes are not cleaning very well.Any help to how to solve this or is it time for a new machine.Thanks
    #242705
    Internal blockage perhaps? Major disassembly required beyond the rotors and feed pipes. Over the years have seen all sorts sucked into the sump pipes and circulation motor.
