Hiyas,
Got a problem with this machine. 4th and 5th lights are flashing but can’t find this error in the codes. Nothing in the search here either.
PCB has been replaced, reset on PCB done too.
Scratching my head here. Is it possible that the dispenser solenoid would cause this? Solenoid meters ok.
All help, as ever, greatly appreciated.
Machine will sometimes do a full wash, most times aborts and lights 4 and 5 flash.
Already cleaned out the hose and what have you.
Door switch is fine too.
4th and 5th lights flashing isn’t a listed fault code so I would go with your assumption that the solenoid on the dispensor is at fault to be honest, it causes all sorts off odd errors 🙂
