diplomat adp8132
  • #16792
    mrsbinks
    Please help this is driving me mad.
    i have a diplomat adp 8132 which i have not used in a while, as the door lock broke.
    I have now replaced the lock and when i switch on the machine i get a flashing light over the normal setting.
    I have looked in the useless instruction manual and there is no solution for this error.
    i have taken the lock off and put back on twice to make sure i have fitted it correctly and i am 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure i have.
    Has any one any suggestions. 😥
    #171534
    Re: diplomat adp8132
    5 lights, from the left which one is lit? 1-2-3 etc?
    mrsbinks
    4th one from the left
    #171536
    That’s not a recognised fault code – try the reset procedure, it’s outlined as part of this thread:
    http://www.ukwhitegoods.co.uk/modules.p … omat+reset
    Might work, if not, engineer time.
    mrsbinks
    ok i reset the machine hooray it worked but now when i try to set a program. it will start working on one and work its way through to five.
