Diplomat ADP8132 dishwasher. (Smeg clone). Type:- 12043. Nr:- 18244 0901.
Original fault was a blown PCB (water ingress) so replaced it with a s/hand item – PCB numbers match, model no. matched.
Worked a treat for about a month and then a fault develops – the machine won’t finish a cycle. I checked everything and found that the socket the machine was plugged into was intermittent. Great; sorted the socket problem but the machine would still keep washing until you turned it off. 👿
Went back today and tested everything. Start a cycle, the machine fills, then washes for about 4 minutes: it then stops, beeps and repeats this loop again and again. Put a test meter across the heater and found that everytime the PCB switched the heater on, it stops, beeps and restarts the program. Heater tests out fine.
I’m thinking goosed PCB……any thoughts??
Thanks,
Steve.
