Diplomat ADP8132 prog. jammed
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat ADP8132 prog. jammed
  • #14089
    simtoms
    This Dip. ADP8132 has the strong wash light (fourth from the left) jammed on and you can’t get it to do anything else but bleep at you. No water taken in. Pressure switch reset. Board diconnected and reconnected… Doesnt seem to fit the usual fault codes… anyone been here please?! simon. 😕
    #158045
    Re: Diplomat ADP8132 prog. jammed
    A long shot but try this:With door open, switch on mains switch and hit the button 4 times quicky before the led comes on, see if anything changes, if so switch off and try and start it again, if no luck then the pcb is shot.
