Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP8221 detergent dispenser won’t open
- This topic has 6 replies, 2 voices, and was last updated 21 years ago by
pittpony.
March 30, 2005 at 10:27 am #8750
pittpony
ParticipantHi there,
I’ve just moved into a house complete with a Diplomat ADP 8221 integrated dishwasher. Unfortunately, no matter which cycle I try to run the detergent dispenser just will not open during the wash. While this is obviously very economical in terms of detergent, my plates aren’t getting very clean! Any advice would be gratefully received. I tried calling Diplomat but the number on the brochure wasn’t recognised…
Thanks,
Nick
March 30, 2005 at 4:26 pm #130258clivejameson
ParticipantRe: Diplomat ADP8221 detergent dispenser won’t open
It will almost certainly need a new soap dispenser…the operating solenoid within it will most likely have failed.
If you look in Repairs@ you might find an engineer in your area, failing that then you can ring MFI (it’s one of their own brand machines) on :-
0870 607 5093
Hope that helps?March 31, 2005 at 10:43 am #130259pittpony
ParticipantThanks for your help Clive. Unfortunately a Repairs@ search showed no engineers in Canterbury… I called MFI and they quoted £60-80 to fit a new dispenser plus £40 for the part. Does this kind of money seem reasonable for fitting? I’m tempted to have a bash myself.
Cheers,
Nick
March 31, 2005 at 3:40 pm #130260clivejameson
Does seem a tad high but thats what you will have to pay when you deal with national retailers and manufacturers. You could look for a local independant who will probably be a little cheaper…just ask your friends/neighbours if they have used anyone they can recommend.
If you wish to attempt it yourself then firstly unplug the appliance. For an engineer it is an easy job, the thing to be most careful of is the very sharp door edges that are exposed when doing it.
If you contact Shop@ with the make/model/serial then the part can be supplied to you.
I should add that i have seen some pcb failures that will cause the dispenser to fail so unless you are competent to check for this then it would be better left to an engineer.April 4, 2005 at 8:13 am #130261pittpony
Thanks Clive,
I might get a local engineer if i can find one but i’m having a job finding one that’ll answer their phone!
Just out of interest – you mention pcb failures… What does this mean?
Thanks again for your help.
Nick
April 5, 2005 at 7:47 am #130262clivejameson
Nick
The pcb is the main control circuit board 🙁
April 9, 2005 at 5:36 pm #130263pittpony
Well i ordered the part through this site. Cheaper than MFI and came through in a few days – what an excellent service!! Am doubly chuffed as i had a go at fitting it and now have a fully working dishwasher! Don’t want to tempt fate though seeing how many posts in this forum seem to say “my diplomat has broken”!!!!
Chers for all the help
Nick
