Hi all, this washer has developed the above fault, It will run full cycle but only cold. The matrix and spay arms and filter are clean, heating element reads 30 Ohms -OK.
The thermostat is located between the element, it has 4 spade connections 1 pair closed cicuit the other pair open circuit. Looking for a replacement for this model only shows up a 2 connection type (977870006) I am confused as I cannot seem to find a 4 connection stat for this model. thanks
