Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat adp8234
- This topic has 4 replies, 2 voices, and was last updated 20 years ago by
wisethebap.
March 30, 2006 at 11:16 pm #16800
wisethebap
ParticipantCan anyone please advise if it is possible to replace the LCD control display on an adp8234 without replacing the complete control / dood lock plastic housing ?
The display isn’t lighting the correct segments so it’s impossible to tell which program is selected. Counting the beeps doesn’t get the correct program every time, suggesting it’s a bigger problem than just the display. I’ve over come the E9 code a while ago with the forums help and don’t want this to get get the better of me
ThanksMarch 31, 2006 at 7:20 am #171633Dave_Conway
ParticipantRe: Diplomat adp8234
If the PCB is at fault, yes it can be replaced but it isn’t cheap. Part number 696290762 at £114.81 ex VAT and carriage 😯
If you’re certain it’s failed and need one, an email to spares@ukwhitegoods.co.uk will get things under way 🙂
Power off when checking :zap: or if you’re unsure and would like an engineer to check for you, check the repairs@ link below.
March 31, 2006 at 12:23 pm #171634wisethebap
Dave thanks for the reponse.
Any easy way of checking if it’s the PCB? The machine is still working, it’s just a bit of a guessing game which program it’s going to run, but at 114+vat I might be willing to put up with it.March 31, 2006 at 12:39 pm #171635Dave_Conway
There’s no 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} way of checking to be honest but if it’s working OK (especially the dispenser opeing every time) then it can’t be much elase really.
April 4, 2006 at 7:47 pm #171636wisethebap
Well after another weekend of ‘guess what program I’m going to run’ 😈
and the glasses on the top rack coming out with the all to often grit deposits (took the machine apart & cleaned out the fill-chamber again a few weeks ago) I admit defeat. 😥
Now I’m sorry not to give you the spares work but to be honest I think the £114 for the new PCB would be better spent on a new machine.
So, I know no make is perfect, but you boys must know which makes are better than others, any suggestions (apart for buy a pair of Marigolds)?
Thanks -
