Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP8234 error code E9
- This topic has 11 replies, 5 voices, and was last updated 21 years, 3 months ago by
BT.
January 4, 2005 at 8:31 pm #7321
BT
ParticipantHas anyone any ideas as to where this fault lies? The machine goes through the pre wash cycle, filling and draining as expected, but will not progress on to the main selected wash cycle. I have pointers on codes E1 to E6, but no further. I have tried with the timer on/off and it does not differ. Any thoughts would be welcomed.
January 4, 2005 at 8:38 pm #122676eastlmark
ModeratorRe: Diplomat ADP8234 error code E9
E9 is pretty much the same as E2. The pressure system is blocked, try cleaning the tube behind the flap in the sump under the filter. If this does not work, the pressure chamber will need changing. An engineers job.
January 4, 2005 at 8:49 pm #122677kwatt
KeymasterTrue Mark, but it’s not a nice one is E9. 😉
It could also be a faulty wash pump as well as a couple of tother little nasties as well. 😕
Then there’s the fact that on the 3 and 5 button earlier timers it’s not an alarm at all but a test program..
Lovely stuff, don’t we all just love fault codes?
January 5, 2005 at 6:58 pm #122678BT
ParticipantCheers lads for the couple of pointers. I’ll have a look at these and get back to you.
January 10, 2005 at 8:18 pm #122679BT
ParticipantThanks Mark for the tip. I have cleaned the tube/flap area, which was pretty gunged up. The machine has now done about half a dozen complete wash cycles and appears to be back to normal. Tried to explain to the missus about the importance of keeping her sump and flap area clean. Didn’t take it to well………..!
January 14, 2005 at 1:09 am #122680admin
KeymasterRe: Diplomat ADP8234 error code E9
Having made further enquiries this week, I have found that the Hotpoint BF72 is a very similar machine. The BF72 is a 5 button program machine whereas the ADP8234 only has 3 buttons. Hotpoint manual gives error codes 1-9. Error code 9 is pressure switch fault. I took off the R/H side panel & found the bottom of the air break chamber sludged up. I took the chamber off the machine(only held on with 2 screws & large plastic ring) & cleaned it out with hot water quite easily. I also cleaned out the link pipe into the sump. Put it all back together & it works fine.
PS Dont you just hate getting integrated machines out & in!! (especially when the floor tiles stop in front of the feet)
January 14, 2005 at 1:19 am #122681Penguin45
ParticipantWell done; eastlmark’s post was correct, although kwatt’s comment is perfectly valid.
Kitchen fitters rarely stop to consider the consequences of how they install an appliance – it drives all of us bonkers.
Penguin45.January 14, 2005 at 8:21 pm #122682eastlmark
Just to rub it in, had an E9 this week and it is the circ pump dammit ❗
April 8, 2005 at 6:53 pm #122683admin
Keymasterany of you boys back from work yet?
I’ve spent the best art of today going through your info on the diplomat E2 faults. Is the hole on the Lhs of the sump the one that goes to the side fill chamber that seems to give most of the trouble?April 8, 2005 at 8:05 pm #122684Penguin45
ParticipantRe: Diplomat ADP8234 error code E9
It certainly is – a thorough rodding out with a tie-rap usually does the trick; a long skinny bottle brush is even better.
Penguin45April 9, 2005 at 2:58 pm #122685admin
KeymasterThanks Penguin45
Had to take the bull by the horns and attack the side fill chamber. It was badly clogged. A good clean and a wash cycle later all seems to be well. Appart from the broken plastic lug that’s ment to hold the door catch in place. Any ideas of a glue that will cope with the 70+ temp, Araldite is only rated to 65 so I don’t expect it to lastApril 14, 2005 at 2:39 pm #122686admin
Hello
Had this fault, found this site, fixed the fault, what can I say surreal or what!! Thank to all it was very useful -
