Diplomat ADP8234 PC fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8234 PC fault
  • #21820
    fobber
    I have a Diplomat 8234 dishwasher. It has just started to become faulty. When you try to access the programs it sits at P0 and then goes to PC. (Normal programs are P1 to P6) . Can anyone help with this PC fault? Thanks ❓
    #192640
    Re: Diplomat ADP8234 PC fault
    You are in the test programme somehow. To exit, switch on, wait three seconds and press the programme button twice, quickly. Switch off, switch back on and it should be OK.
    Is the start light flashing? count how many flashes there are before a pause, and the number of flashes will reveal a fault code, let me know and i can tell you what the problem is.
    the normal codes are 2 flashes – machine leak, 4 flashes – drainage problem, 6/7 flashes – either water inlet problem or “flow meter” failure.
    #192642
    DentedPorsche
    kandl-appliancerepair wrote:Is the start light flashing? count how many flashes there are before a pause, and the number of flashes will reveal a fault code, let me know and i can tell you what the problem is.
    These don’t apply to this machine. Penguin 45 has the right one.
    DP
    #192643
    fobber
    Hello,
    Thanks for that, seems to be working again… dont know bow got into that mode..Cheers
