Diplomat ADP8242
  • #26712
    robwash
    Hi. on arrival on the diplay from the left i found 1st, 2nd and 3rd light flashing. i know from previous that this is for a leak. found water in base and flood switch activated. found leak coming from gasket on side chamber. fixed leak. then tested and flashed same fault. no water in base. i then pulled plug out to reset. 1 min later plugged in machine and right hand 2 lights flashes and can’t reset using prog button. pulled plug out again but the same. any ideas anyone please? cheers rob
    #211137
    Marty-K
    Re: Diplomat ADP8242
    I had a problem on one of these where I couldn`t select a programme or reset and it turned out to be a faulty door microswitch.
    Regards Marty-K
    #211138
    Try and re set by turning on and quicky (before the leds start flashing) press the prog button 4 times. switch off and then try it. May have a shorted circ pump? need to megger it although it may dry out..
    #211139
    robwash
    i’ll try that in a couple of days…cheers makes sense. rob
