Have a strange fault with the above machine Fills normaly goes to wash for 1.5 mins then the machine stops dead with no lights flashing.
Checked Heater, pressure system, Pump and fill matrix all OK Begining to think PCB any help appceiated
Dave, I should have remembered that from all the previous posts on the subject. Could I just wire in a good coil to see if it cures the fault before I order a new dispenser?
Thanks Guys
This is for a very long standing and loyal customer of mine and
one who I would go the extra mile for. So I hope its the
dispenser rather than the PCB as I know she cant afford the price of a new circuit board.
Called back today, Fitted new coil same fault! In desperation I adjusted the water level on the P/switch Remade the conections to the new coil and It then started working ok 😕 Not sure now if it was just a bad connection the the wax motor on the dispenser or a water level prob.
told cust to try it over the weekend and I will call back Monday
