Not havin’ a good week so far so hope you can help!
The above m/c fills,washes for about 2-3 mins then stops. No neons flashing up any fault codes or any bleeps either. Disconnect drian pump to test & check ,all ok, reconnect pump, switch back on & m/c then empties! It does this every time. It’s as though every time you reconnect the pump,the m/c resets itself, & empties. Carnt be the pump as it starts up at the start of the prog before filling. I think this Diplomat might be a Whirlpool clone!
Hope someone can help, it’s doing my ‘ead in 👿
