I have a Diplomat ADP8242, all good until last week, cycle (eco) starts perfectly, then stops, beeps twice and starts again. This sequence then repeats until I turn the washer off.
The washer fails to drain and Pi**es water all over the floor!
I have cleaned all possible filters/housing, checked for blockages, reset the plc and buried a steak in the garden at full moon.. now i’m running out of ideas and hair please help me….
PCB error, I would suspect…… Fault is not “logical” and you’re not getting an error code. Dispenser unit will often blow the the PCB, so you may need both.
The PCB is over £100, plus VAT – I would seriously suggest getting pro help in this – avoid expensive mistakes. Click the link below for a local UKW engineer.]
Power off if you are going to investigate, please.
