Diplomat adp8322
  • #37613
    msappliance
    i think this is a cda appliance.
    fault 4 showing
    i need to know what could the most common cause be if its the ows that is faulty sensor where is it and can it be cleaned by hand?
    any help will be great, thanks.
    #255820
    Re: Diplomat adp8322
    Whirlpool….. Page 1 – Known Error Codes.
    msappliance
    can someone please tell me what the o w s sensor looks like and how to remove it, thanks, mike
    #255822
    subs
    Have had a few problems with this fault on this machine myself lately.
    If you are talking about the where abouts of the water sensor/indicator/pressure switch (not sure what correct term is) then its as follows. Remove filter and metal mesh from sump inside m/c. Look in the sump at 3 o’clock and you will see small black plastic grill. This is it. To remove it you have to get under sump and it just twists off like bosch drain pump. You will see it is just a rubber diaphram that pushes a micro switch. Check switch. You can take the diaphram out and carefully clean it. In the case of mine although the thing looked clean it felt sticky and greasey which was causing it to stick so machine thought it still had water in it when it didn’t. Or if you dont want to mess about, just replace it.
    Hope this helps
    Subs
    #255823
    msappliance
    thats the one, thanks a lot.
    Mike.
