Diplomat ADP8322
  • #38378
    maltheviking
    Six flashes fault, WI nice and clean 🙂 Can the water flow meter (reed switch) give the same fault ? 😕 and has anyone the part no. for it please?
    #258665
    DentedPorsche
    Re: Diplomat ADP8322
    Hiya,
    6 flashes is normally the flow meter. Bad connection is the favourite, unplug it, clean pcb, tighten plug, plug back on and it should work.
    Complete metering tank if you want to change the flowmeter.
    Brian
    #258666
    maltheviking
    Flowmeter 481241818338 I presume ?
    #258667
    Seamy
    Seeing as we’re on Diplomat D’Ws i’ve been to one today an ADP8352 that will only show P0 on display, won’t reset to any other program. Is it a dodgy electronic or any other ideas ?
    #258668
    Whirlpool to SMEG……..
    Duff pcb possible because of:
    1/ dodgy suppressor
    2/ dodgy soapbox solenoid
    3/ dodgy motor capacitor
    DentedPorsche
    Don’t forget……………….. door lock turned over and machine thinks the door is closed.
    Brian
