Diplomat ADP8322
  • #41587
    sparrow1
    I have a Dishwasher Diplomat ADP8322. (Basically a re-badged Whirlpool) This is causing my power to trip out. It is out of warranty therefore I want to try and fix it mysekf, Has anybody had this problem, as I would like to test a couple of ideas and order the part from Dave ib the office?
    Many Thanks
    #270682
    Re: Diplomat ADP8322
    heater element is a favorite or you may have a leak and the water has got on something causing the trip. Need to remove the bottom panel under the door, if you have a leak the tray covering the base of the machine will have water in it. Makes sure you unplug before doing anything and if the fault is not obvious, you will need a test meter to establish the cause.
    #270683
    sparrow1
    I have checked and there is no water. Is the heating element easy to replace on this machine. Is there anywhere I can download a circuit diagram?
