We have recently moved into a new house and our dishwasher is now playing up. The dishwasher is a Diplomat ADP8322. We have no manuals for this anywhere in the house.
The dishwasher starts up and seems to fault out when the water is filling. The dishwasher will get to this stage and fault out with an F7 fault.
Reading your suggestions in other forums I have checked that the incoming water wheel is turning and that the sensor monitoring this is switching. I have cleaned all contacts and closed the crimps.
The sensor without the water flowing is around 8Mohms and with the water running it changes to 6Mohms. I dont know if this resistance is to high so I linked it out when filling was happening.
The dishwasher still faulted.
I’m now not sure if its the sensor or the controller as the sensor goes straight back to the controller.
Can anyone help me identify parts?
Any help would be greatly appreciated.
The water wheel assembly comprises a magnet in the wheel itself and a reed switch on the pcb. Therefore, it’s a switch, so readings should be either infinite or zero ohms.
