Hi all,
Recently dishwasher has developed the 4 flash fault. I have tried cleaning the Diaphragm but still doesn’t work. Before I buy a replacement just one question.
On a short cycle (30 minute one for example) it completes fine. It only appears to fail on the long cycles but always at the same stage. At the end as it appears to do the last drain before completing. I can hear it drain fine a good 3 times before it errors.
As its fine on short cycles and appears to drain fine about 3 times before it fails can it be the Diaphragm and sensor? or is it more likely the control board?
Cheers
Iklekid
