Diplomat ADP8322
  • #55652
    allan73
    Can anyone help me out with a fault code on this whirlpool built dishwasher, it runs for a short while then 1st light on left comes on and start light flashes constantly also it beeps constantly……… 😡
    Thanks in advance guys.
    #324626
    allan73
    Re: Diplomat ADP8322
    Ive read on here this could be a NTC fault is this correct ?
    #324627
    yes you are correct
    1 flash fault code look like a constant flashing light
    but check closely from memeory you can have anything up tp 15 flashes so watch it closely for at least 20
    i keep a spare ntc as a test had a few where it did not cure fault so had to assume board faulty
    hope this helps
    allan73
    Thanks Dave,
    I watched for quite a long time & there was no pause but i will double check.
    #324629
    allan73
    Can i test the NTC with a meter ? They’re not that cheap (whirlpool GRRR!)
    #324630
    just measered a new one at room temp (out of the machine )
    54K ohms
    hope this helps
    dave
    #324631
    allan73
    Thanks again Dave 🙂
