THIS IS A WHIRLPOOL DISHWASHER WHICH STARTS TO FILL ON ANY PROGRAMME FOR ABOUT 30 SECS THEN STARTS TO PUMP OUT ALL THE WATER AND STARTS BLEEPING THE START BUTTON FLASHES ALL THE TIME AND THE PROGRAMME JUMPS BACK TO THE PREWASH PROGRAMME LIGHT BUT DOES NOT FLASH JUST STAYS LIT ANYBODY GOT ANY IDEAS AS I CANT FIND ANY FAULT CODE RELATING TO WHAH I GET.HAVE CHECKED THE BASE NO LEAKS 🙁
Stop shouting I have a headache!!
Take out the pcb and if you have a magnet run it alongside the pcb reed switch whilst putting a buzzer or meter across the two contacts, if it doesn’t give a reading (or buzz) the preed switch is goosed. Had loads do this. Also check the path back to the main pcb for poor connections. HTH
Normally Whirlpool code is 7 flashes for faulty flow meter so if checking / replacing it doesn’t work, you could try looking at this threadhttp://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=3&t=64457 and pm me if you need further info.
The symptom is different but I have a suspicion the fault may be the same.
Mike.
