Diplomat adp8322 854500015819
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat adp8322 854500015819
  • #46038
    bazza500
    I have this d/w which does a 40oC wash fine but if you try and do a 60oC or 70oC wash it finishes the program fine but beeps with the rinse light on and the start light gives 4 flashes.
    It is completing the cycle and finishes with no water in the tub, and steam when you open the door but why am I getting a fault code.
    Baz
    #288000
    DentedPorsche
    Re: Diplomat adp8322 854500015819
    Hiya,
    4 flashes indicates a drainage failure.
    If it’s draining fine it’s normally the water indicator that causes the problem.
    Don’t know why it would ok on the lower wash though.
    Brian
    #288001
    bazza500
    Do you have a part no. for the water indicator and where the hell is it? 🙂
    #288002
    DentedPorsche
    Hiya,
    The water indicator is the black grid on the right side of the sump.
    Unfortunately I don’t have a number for it handy.
    I’ve always been pretty lucky with them, cleaning them out normally gets them going.
    481227128407 is the one in the Shop@ so should fit ok.
    Brian
    #288003
    adv
    a had one like this. changed every thing even pc board. gave up in end .nightmare 😆 😳
    #288004
    bazza500
    Thanks adv, that makes me feel better 🙂
    #288005
    adv
    soz a spent week tryin to fix it ma save u time an money lol 😳
    #288006
    Simon46
    Pasta spaghetti in grid usually.
    S.
