I’m assuming it’s a fault code 7 – it gives 7 flashes followed by a pause. Basically when I start the machine it enters the fault mode almost immediately. If I clean the filter and the spray arms it is usually okay.
MFI say it’s a water flow problem and is normally the water chamber needing replaced. I guess this could be a trick to get a technician out (my machine is over a year old).
