Diplomat ADP8322 D/W
  • #51916
    jontymox
    Good morning all,
    Wondering if anybody can help with a problem on the above d/w
    Evidently the m/c goes onto the rinse cycle after around ten minutes operation, having selected one of several “normal” wash programmes.
    Thus, the programme does not run its full course.
    I have had a look at the m/c and suspect the pcb/control unit inside the door housing.
    However, as they are rather expensive I don’t want to quote/fit a new pcb/control unit and not rectify the fault.
    I appreciate they are very difficult to test, and wonder if I am concentrating on the correct unit, or if another fault could be causing this. (the connections and unit appear ok as far as I can tell.)
    I would be grateful for any help on this matter.
    jontymox
    #309853
    Re: Diplomat ADP8322 D/W
    Is the start light flashing when it fails? if so count the number of flashes between pauses and look it up in the error codes trhead. Its a Whirlpool model.
