Diplomat ADP8322 (D/W)
  • #61420
    rocker
    just received a call customer tell me the internal plastic feed pipe that goes from base to top spray arm keeps coming adrift from the base unit…is this a common fault..will it resolve by fitting new feed pipe, or will it require a base unit as well…!!
    thanks John
    #346046
    martinm
    Re: Diplomat ADP8322 (D/W)
    usually these two parts needed, the plastic clips break
    http://shop.ukwhitegoods.co.uk/Dishwash … pport.html
    http://shop.ukwhitegoods.co.uk/Dishwash … +Igni.html
    #346047
    rocker
    cheers Martinm. john
    #346048
    keithwilliams
    don’t call me a cowboy but….
    i carry very small stainless steel self tapping screws.
    i explain to customer what i’m going to do and they all agree.
    basicaly i make a minute hole in filter cover next to supply tube. then screw in screw at angle through cover and slightly into the tube. it will never ever come out again.
    also check spray arm nozzels for blockages which would cause back pressure.
    no parts need = cheaper job = very happy customer.
    #346049
    martinm
    COWBOY
    lol no thats a good idea i like it, its just i fitted so many of them parts when i was with mfi we had them on the van.
