Diplomat adp8322 dishwasher
  • #25914
    suedehead1
    this looks like a whirlpool in disguise.
    there was smoke coming out of the bottom of this machine.
    the microswitch on the honeycomb pressure switch was burnt, i put a new microswitch on it, but its now flashing a light 11 times.
    looking at various threads it says that the optical water indicator is faulty.
    i got a parts diagram and parts list there is no owi listed.
    can anyone tell me what it is and where it is any part numbers welcome.
    if anyone has any ideas i would also appreciate it.
    thanks in advance.
    #208096
    DentedPorsche
    Re: diplaomat adp8322 dishwasher
    8322 is a Whirlpool. If by the honeycomb you mean the black grid in the sump, that’s the WI. There is no OWI on this machine so it’s misreporting the fault.
    What are the symptoms?
    Brian
    #208097
    suedehead1
    the machine takes in a little water the stops with the light on the left lit and the one on the right flashing 11 times
    #208098
    DentedPorsche
    Re: Diplomat adp8322 dishwasher
    OK, for some reason it’s misreporting the error code. The 8322 doesn’t have an OWI fitted, only an WI.
    As the WI switch was burned I’d be inclined to start with changing the WI.
    You could be unlucky and find that the software on the module has been scrambled.
    Fill problems are usually down to the flowmeter (bad connection) and the WI.
    Brian
