Diplomat ADP8322 dishwasher FA fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat ADP8322 dishwasher FA fault code
  • #22514
    RickT
    Looked at one of these today. Fills up to base of salt cap as normal then aborts with 11 flashes (FA code) optical water indicator fault. Removed said item from sump, all clean but rinsed it out anyway. This part looked in principle like a pressure switch similar to the old Hoover T5004 wash sump switch. When blown into, micro switch no/nc tested ok. Still getting same fault. Any ideas?
    Rick
    #195299
    gegsy
    Re: Diplomat ADP8322 dishwasher FA fault code
    WI could be faulty or poor connection. Failing that worse scenario could be faulty PCB.
    RickT
    Hi Greg
    Revisted this machine today. On starting progamme, waited for it to fill and show error FA. Checked circuit from pcb WI connector down to water indicator and back, all was fine (closed circuit). Can I assume that the fault is in the pcb as I’ve tested all other components??
    Cheers Rick
    #195301
    DentedPorsche
    Emmm, Isn’t 11 flashes FB?? Diverter valve stuck.
    Brian
    #195302
    gegsy
    Hi Brian
    I have codes for that goinf from F1- F8 then goes FA then FE. No mention of 11 flashes or FB so now Im confused 😕 🙂
    FA is WI problem or related fault.
    DentedPorsche
    Hi Greg,
    You’re right. 11 flashes is FA. F0 (the first one on my list) is 10 flashes.
    I’ve altered my post on known error codes to include the number of flashes.
    You’d think I’d know better, I’ve got an 8322 and it doesn’t have a diverter valve. 😳
    Brian
    #195304
    cornwell40
    I have the same, is the OWI 5031682990384 on connections?
    Can’t find manuf. description anywhere.
    TonyC
