Diplomat ADP8322 Dishwasher Inlet TubeSpray Arm Assy Removal
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8322 Dishwasher Inlet TubeSpray Arm Assy Removal
  • #68836
    Rob_D
    Can anyone advise how to remove the Inlet Tube / Spray Arm Assy from the top mounting? The tube easily pops out of the lower mounting (that’s why I need to replace it) and the back mounting easily unclips but I cannnot see how to remove the tube from top underside of the dishwasher. Is it a snap fit? I don’t want to force the plastic in case I break something. Would appreciate how to remove the tube prior to ordering replacement parts. Rob
    #372924
    mjjuk
    Re: Diplomat ADP8322 Dishwasher Inlet TubeSpray Arm Assy Rem
    Before you go to the trouble of removing this part ensure you don’t need part 480140102074 this is the housing that the spray arms clip in to if you are getting a problem with the feed tube popping out the little clips that hold it in place have probably snapped (a lot easier to replace)
    #372925
    Rob_D
    Hi “mjjuk”. Thanks for your response. Have checked the Filter Cover as suggested and lo-and-behold the retaining clip feature has broken! So have now ordered the relevant part and will advise if this totally solves the problem. Many thanks. Rob_D
