Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP8322 Error Code 4
- This topic has 7 replies, 4 voices, and was last updated 18 years, 1 month ago by
Swn-Y-Mor.
March 1, 2008 at 1:33 pm #34974
Swn-Y-Mor
ParticipantHi,
I have a Diplomat adp8322 which is about 3 years old. It has recently develpoed a fault :-
Cycle stops on rinse and light flashes 4 times
Any help appreciated
March 1, 2008 at 2:07 pm #244631gegsy
ParticipantRe: Diplomat ADP8322 Error Code 4
Either the machine can’t empty or the WI (water Indicator, 3 oclock position below filters) is clogged up or faulty.
At worst it could be the PCB module. 😥Power off if you are to investigate :plug:
March 1, 2008 at 2:28 pm #244632Mandolin
Had a similar problem light flashes 4 times, eventually found the filter underneath and twist off. Completly bunged up with grease. Once cleaned ren like new
March 2, 2008 at 6:07 pm #244633Swn-Y-Mor
gegsy wrote:Hi
Thanks for your reply. Is the Water Indicator removable? to unblock?
I have checked that bottle traps under sink, and all spigots and pipes are clear. There is water sitting in the sump where the filter sits. Is this normal?March 2, 2008 at 6:17 pm #244634Penguin45
Penguin45 wrote:OK, one more time…….
Remove the filters and look into the sump. At the 3 o’clock position there is a black plastic grid – this is the water level sensor. The area behind the grid will be full of congealed fat, jamming the operation. You may hit lucky and an old toothbrush and plenty of hot water will let you scrub the device clean. If not, it’s a twist fit from underneath and then you can really get to work on it. Power off if you have to go that far.
Penguin45.March 3, 2008 at 10:47 pm #244635Swn-Y-Mor
After difficulty getting integrated dishwasher out of housing, and removing side and bottom coverplates, I finally removed that black plastic grid thingy. It was a bit gunged up. Strugglked to put everything back together. Bleeding knuckles too
The dishwasher is about 30 mins into its cycle, and no beeps yet. I hope I’m not too premature here…. 🙂
March 3, 2008 at 10:58 pm #244636Swn-Y-Mor
Arghhhhhhhhh……….. 😳
45 mins in it starts beeping. I open the door and the beeps get much much faster (not much of a gap between beeps)
Light flashes 4 times againBack to the drawing board
March 5, 2008 at 5:21 pm #244637Swn-Y-Mor
Any other suggestions?
