diplomat adp8322 fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat adp8322 fault
  • #34136
    flipper1
    as the cycle starts the machine will then bleep constantly and the green light on the rinse only cycle flashes. I have tried tilting the machine backwards ( as advised) but this dosnt seem to work. any ideas?? :rolls:
    #241419
    Re: diplomat adp8322 fault
    Fault indication should be by the start neon flashing in a pattern. Try holding down the start button until the light goes out, shut the door and let the drain pump run until it stops. After that you should be able to re-programme and see what happens.
    flipper1
    thanks P45 but i have already done that. I have had advice that it is the overflow sensor, and after tilting the machine backwards and letting the water drain out it ran a full cycle, but then the error returns straight away.
    where is the overflow sensor located and is it worth changing it?
