My 3 and a bit year old dishwasher seems to have been causing the RCD on the consumer unit to trip for about four days but was working OK until I fired it up yesterday. We always use the 65 degree wash cycle.
The washer now will not heat and will start beeping mid cycle, sometimes after five minutes or so, sometimes after as long as 80 minutes.
When you open the door, the LED by the start button is flashing three times and the Rinse proramme LED is lit. The water has drained away. Open the door mid-cycle and the spray arms are all OK, but the water is cold.
Since switching the machine off the RCD has not tripped again.
I’ve searched the forum and found similar faults, but not identical. Any clues? Is it worth repairing and if it is, is it an engineer job and if so, is there one in the BD10 area you could recommend?
Thanks for any help.
