diplomat adp8322- flow meter?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries diplomat adp8322- flow meter?
  • #32671
    smeghead
    diplomat adp 8322 starts to fill then aborts- 7 flashes on start button.
    error code indicates flow meter , but cant see anything wrong, not blocked, or am i looking at the wrong part. i assume flow meter is fill chamber on lhs. checked all usuals any help appreciated.
    #235966
    Simon46
    Re: diplomat adp8322- flow meter?
    I found this out
    http://www.ukwhitegoods.co.uk/modules.p … =flowmeter
    Regards
    S.
    #235967
    A good clean of the contacts and a nip of the connector block will usually get it going again.
    But not always…….
    Can be flow meter itself (fill chamber assembly) required, or have had one where it turned out to be the computer not counting the pulses.
    smeghead
    thanks for advice, will check wiring connection again and fit new tank if required.
