Diplomat ADP8322 giving two separate errors codes 6 & 7
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8322 giving two separate errors codes 6 & 7
  • #49873
    StevieA
    Hi, problem here with integrated Diplomat ADP8322. After setting a program and closing the door, it pumps out for a few seconds (as normal), then starts to fill for a few seconds, then stops and beeps. If I open the door at this point, it shows the rinse symbol and 7-flashes error message. If, however, I allow it to then go through a short pump out sequence and wait until everything stops and open door, it shows the 6-flashes error message (with the selected temperature light lit). This is very confusing after reading all available posts as I don’t see this mentioned. I’ve cleaned the filters at the bottom, and also squirted water into the black grille (as mentioned elsewhere – I had a similar problem a few years ago and this solved it).
    The problem arose mid cycle, after washing dishes but not after fully rinsing them (they felt a bit slimy), but the machine did pump out OK.
    Any ideas? Help much appreciated.
    #302601
    martinm
    Re: Diplomat ADP8322 giving two separate errors codes 6 &
    it will be a faulty flowmeter, you can only but it with the air break complete its behind left hand side panel. link for part below
    dont forget to unplug power before investigating!
    http://shop.ukwhitegoods.co.uk/Dishwash … amber.html
    #302602
    StevieA
    Thanks for this. I’ll try cleaning up the contacts etc first (as mentioned in another thread) then buy the part if that doesn’t work.
    #302603
    clivejameson
    StevieA wrote:Thanks for this. I’ll try cleaning up the contacts etc first
    Always a good first step 😉
    Power off at all times :zap:
    #302604
    StevieA
    Cleaning contacts didn’t help so I ordered the part as suggested. Arrived in a couple of days, fitted, and now works perfectly. Many thanks for your advice!
