diplomat adp8322 integrated dishwasher problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat adp8322 integrated dishwasher problem
Viewing 15 posts - 16 through 30 (of 31 total)
  • #110623
    nicpillinger
    Re: diplomat adp8322 integrated dishwasher problem
    thanks for the info, I think its a spigot under the sink. I’m not sure what you mean by blanks though? where should I look for them?
    #110624
    I get the same issue with the Diplomat ADP8322 where after drainage when a cycle starts it beeps and the light flashes 5 time then pause any idea?
    #110625
    Oops make that 6 flashes
    #110626
    Dave_Conway
    aswee wrote:Oops make that 6 flashes
    Is this the same fault you sent me an email about ?
    I’ll have a look when I’m in the office tommorow for you 😀
    #110627
    Dave_Conway
    I can’t seem to find the codes list for that exact model, but generally all of these Smeg made dishwashers use the same codes.
    F6 is not draining, so check for blockages in the waste system etc.
    Regards
    #110628
    i seem to have the same ntc problem with my diplomat adp8322 which is typically 1 month out of warranty – arghhhhh! Can you recommend an engineer in the surrey/ hants area?
    Thanks in anticipation……
    #110629
    What postcode area tiff?
    hi
    my postcode is gu51
    thanks
    tiff
    #110631
    Hi Tiff,
    Alton Electrical Services on 01420 86194
    M Lee Appliance Service on 01483 764851
    Both are listed as covering all GU postal areas. 😉
    thanks very much
    #110633
    Hi, I’ve just moved into a house where they installed one of these dishwashers, never been used but they did’nt leave the instruction manual.
    I’ve put salt in, added rinse aid and a glass protector and set the salt to the lowest setting but everything is coming out with a salty film and I’m having to hand rinse.
    Has anyone got an instruction manual they could scan and email to me? Or look up what I should do with regards to this problem?
    Thanks!
    #110634
    stanehyve
    can anyone help with my diplomat adp 8322, the light above the rinse button stays on and it keeps bleeping. When I turn the power off and then on again and set it going again at say 70 it just goes back to the rinse button with light on and the bleeping. This is my first post so I hope I have done it correctly.
    Regards STANEHYVE
    #110635
    Apart from the double post, you’re doing fine and you’re very welcome. If I read the thread correctly to date, you have the famous NTC failure fault. This is the temperature sensor not being detected by the computer. There are several other technical possibilites; in all honesty a service call would be the most efficient way of dealing with this.
    Check Directories or Repairs@ for a UKW engineer in your area.
    If you wish to investigate further, pull the plug first. :plug:
    stanehyve
    Thanks for your help, sorry about the double post 🙄 I must of clicked the submit button twice.
    #110637
    stanehyve
    which one is the temperature sensor? AWECO 2757.01 or TYPE 2700038
    Regards Stanehyve
