Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › diplomat adp8322 integrated dishwasher problem
- This topic has 30 replies, 9 voices, and was last updated 22 years ago by
admin.
April 6, 2004 at 7:31 pm #5332
Keymasterdear all,
after a few months of trouble-free operation i’m starting to have problems with this model. whenever you try and start a programme the first light on the panel lights up (symbol of water-spray above it) and the go button flashes and there’s a regular beeping sound. any ideas what this means? am in the oxford area if anyone’s local!
cheers!
bodajmac
April 7, 2004 at 5:08 pm #110609admin
KeymasterRe: diplomat adp8322 integrated dishwasher problem
sorry, only just seen this one.
Will reply tomorrow when back at work if u still require helpted
April 7, 2004 at 5:15 pm #110610DentedPorsche
ParticipantRe: diplomat adp8322 integrated dishwasher problem
Count the number of flashes, they will correspond to an error code.
On error condition (whatever the error) it will always revert to first program (rinse) and the start button will flash. There will be a number of flashes then a pause and the flashes will repeat.April 7, 2004 at 10:40 pm #110611bodajmac
remembered the log-in this time! it’s still a problem i’m afraid – we’ve got a callout booked for next tuesday but any help to solve it before then would be much appreciated!
not having much luck with the number of flashes approach – i gave up once i’d counted to 50, so i suppose this might mean that the code in question is just a single flash with a pause after each!
thanks in advance everyone!
bodajmac
April 8, 2004 at 6:54 am #110612DentedPorsche
OK. If this is the machine I’m thinking it is, Whirlpool badged, single flash is NTC fault. (Water temperature sensor).
April 8, 2004 at 12:30 pm #110613bodajmac
thanks for the info – i’m fairly sure the service people said it would be a whirlpool engineer coming out, so that makes sense. if it is a problem with the water temperature sensor does that mean a replacement part is likely to be required? is it usual to get this kind of failure after only 4 months or so of use?
thanks again,
bodajmac
April 8, 2004 at 8:59 pm #110614admin
There has been a problem with NTC failures over several months and the design of the ntc has changed.
If you have a whirlpool engineer coming out then there are only two NTC’s in the range and both should be van stock.
Whirlpool give 12 months guarantee on the repair so make sure you get a proper job docket from the engineer as the repair will carry 12 months warrenty which of course will outlast your appliance guarantee.
You might find it handy to save this proof of repair for 12 months in a safe place( nudge, nudge, wink wink etc….ted
April 12, 2004 at 12:26 pm #110615admin
Hi Everyone
I’ve just stumbled across this site as I’m trying to trace a Diplomat ADP 8322 Dishwasher that’s about to be installed in a flat that I’m buying. This appears to be the only reference on the web for this particular ‘Whirlpool’ machine? Can anyone explain the lack of sites selling this model and where the developers may have possibly sourced this machine from? It seems a strange choice to me. Any background info much appreciated.
NigelApril 12, 2004 at 6:02 pm #110616kwatt
KeymasterHi Nigel,
Probably the reason that you can’t find much in reference to that particular model number is that it a special made for MFI, who also own Howdens, the builders merchant. The connection with Howdens is the most likely reason that the developers have used that appliance.
HTH
April 14, 2004 at 9:07 pm #110617bodajmac
hi again all,
just wanted to say thanks very much – the man from whirlpool came to check it out and it was exactly as you predicted, a problem with the NTC which he replaced there and then, and everything’s working fine now. this is a great site – thanks again!
bodajmac
April 19, 2004 at 8:23 pm #110618spidersmith
Hi all,
I have just installed my ADP8322 and I am experiencing the following problem: about 10 minutes into any wash program the machine starts to beep. The Start light is flashing to the following code: FLASH-FLASH-PAUSE repeat…
Does anyone know if this corresponds to a simple problem that I can rectify or should I call MFI and have the machine repaired/replaced?
Any help would be much appreciated.
April 23, 2004 at 8:11 pm #110619DentedPorsche
I really wish I knew all the model numbers by heart. Don’t though so guessing this is a whirlpool. If it is, two flashes = fault code F2
F2. Water leakage. Floater switch LS6 in drip tray has switched
April 30, 2004 at 9:26 pm #110620DentedPorsche
Oooopppppssssss. The other thing to check is that the water isn’t being siphoned from the machine. Had one today with the drain hose too far into the stand pipe. As it started to wash it emptied, bringing up the F2 error.
May 20, 2004 at 12:36 pm #110621nicpillinger
ah this sounds like the exact problem I have with a brand new whirlpool built in dishwasher. its beeping continuously and flashes 8 times- any idea what this code is? Have got a callout booked but both me and the missus work all week and first saturday they can do is in June 🙁
May 20, 2004 at 2:57 pm #110622DentedPorsche
8 flashes is a water level failure. Is your drain onto a spigot under the sink or into a stand pipe? If it’s a stand pipe I’d guess it’s siphoning. If it’s a spigot, does the machine drain? If not, check that the blanks are out of the spigot.
