Diplomat ADP8322 No wash sympton
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diplomat ADP8322 No wash sympton
  • #42299
    mrhuggy
    The dishwasher fills but when it should start washing the PCB beeps and the dishwasher drains. Is there an overfill fault causing the pump to operate? I have tried a new PCB to no avail
    #273029
    lerch
    Re: Diplomat ADP8322 No wash sympton
    Open the door just when the pump kicks in to see how much water you have in. Is there water in the base causing anti-flood to start??
    #273030
    mrhuggy
    lerch wrote:Open the door just when the pump kicks in to see how much water you have in. Is there water in the base causing anti-flood to start??
    If it is overfilling,what could be the cause,is there a blockage and if so where? Thanks
    #273031
    lerch
    Blockage could be in metering tank or pressure switch failure / water in pipe if switch has dropped from correct position.
    #273032
    aqualectric
    It’s a Whirlpool machine. One beep then abort is usually NTC failure.
    Steve.
    #273033
    lerch
    I could stand corrected lol. 😳
    #273034
    mrhuggy
    aqualectric wrote:It’s a Whirlpool machine. One beep then abort is usually NTC failure.
    Steve. It keeps beeping have tried a ntc. Thanks
    #273035
    mrhuggy
    lerch wrote:Blockage could be in metering tank or pressure switch failure / water in pipe if switch has dropped from correct position.
    I have not had much experience of this model,where is pressure switch located? Thanks
    #273036
    aqualectric
    Pressure switch is in the sump on the right. Remove the filter and you will see a black circular “grid” shaped item. Before you condemn it, clean it thoroughly with a toothbrush. They often get gunked up and malfunction.
    It is accessed from underneath and is a twist fit in the sump.
    HTH,
    Steve.
    #273037
    mrhuggy
    Thanks for that
    #273038
    Jonah
    Changed one today, will be the pressure switch gunked up, this one was solid with grease/fat couldnt clean it, F4 fault will flash up.
