Diplomat ADP8322 Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8322 Problem
  • #7015
    gibbo
    Can someone please help me with my Diplomat ADP8322 problem please? When I switch it on it defaults to rinse cycle and will not allow me to select above 50’c program and will only perform a rinse cycle even when I select 30’c or 50’c program. Machine is filling and empting the water as it should do so there is no blockage and I am not getting any error codes or flashing light errors. PLEASE can someone give me any answers?
    Alan
    #120938
    Hi Gibbo,
    It is a very strange problem that you describe, in fact I’ve never seen one do that before.
    Are you sure that there’s no error lights?
    If it just fills then empties then it sounds like the old E2 error and you’re gonna need an engineer to call I’m afraid.
    gibbo
    Re: Diplomat ADP8322 Problem
    Hi K
    Thanks for quick reply but I am definitely not getting any error beeps or flashing light errors. I spent four hours on this yesterday the only time I get any errors is when I disconnect NTC, FM, HEW and WV2 sensors
    Alan
    #120940
    Definitely an oddball fault then, very possibly the timer itself but it’s an expensive thing to take a risk on so I’d advise an engineer in this case for sure.
    This is a Whirlpool appliance. On any fault it will default to the rinse cycle, but, it will be accompanied by the start light flashing. If you’re not getting any flashes then it’s a very strange fault indeed and it would point to a module fault. However, as K says, it’s a very expensive part just to “try” and fix the machine. The best option is to call in an engineer.
    DP
    #120942
    gibbo
    I have an engineer booked for Wednesday morning I will let you all know the outcome of his visit
    Alan
