I think the problem is likely to be the circulation motor but was hoping to firm up on this before buying and trying.
The dishwasher will run a full cycle, on opening the door mid cycle the water is just dribbling out of the spay arms and there is a grumbling after the initial drain. No error codes present.
I have had the bottom off and taken the motor out but couldn’t see anything obviously wrong i.e. blades seemed to be intact, hoses seemed to be in tact and no water leakage, blades seemed to bind on the spindle when spindle was turned with some slip before the binding in each direction.
Help please
Also what is the latest pump part number I should be looking for?
Cheers
