Hi, I have an issue with my Diplomat ADP8322 dishwasher whereby the water isn’t draining from the bottom and I get a constant beeping mid cycle and 4 flashes from the indicator switch.
From reviewing the various posts on the site I believe that it is probably a blocked or faulty Diaphragm Switch. I removed the dishwasher last night to get access to the underneath so that I can remove it but as soon as I start tipping it to one side, water starts pouring out onto my feet! I turned it on again to see if the pump can get rid of the excess water and it runs but there always seems to be some water at the bottom which it can’t get rid of.
Is there some sort of drainage plug which I need to pull to get rid of the water at the bottom? If not how can I tip it over??
Thanks,
Mark
