Diplomat ADP8322 stopped working
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Diplomat ADP8322 stopped working
  • #36431
    djbj
    The wash cycle had been noisy for a little while, then during the initial first two minutes (rinse cycle) the machine makes a low thud and then stops All that can be heard is a whurring noise (water pump?) coming from below as if something is jammed or not pumping correctly? There is no beeping/fault code. …thanks
    #250966
    Re: Diplomat ADP8322 stopped working
    Better have a read of THIS then.
    Initial action is drain, then fill, then circulate. Motor not pumping correctly is not a detectable error……..
