Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › diplomat ADP8322 tripping rcd.
- This topic has 22 replies, 5 voices, and was last updated 19 years, 7 months ago by
dougiex.
September 7, 2006 at 7:01 pm #186661
gegsy
ParticipantRe: diplomat ADP8322 tripping rcd.
In all fairness Dougie I think it maybe engineer time as this is seems to be turning out to be not a straight forward fault.
Please feel free to use the engineer link below.
September 7, 2006 at 9:24 pm #186662dougiex
But is it worth calling out an engineer? Call out charge probably about £100, plus possibly £100 for pump. Rather buy a decent reliable make. Is it not possible to check out the motor using a meter?
September 7, 2006 at 9:32 pm #186663gegsy
Hi Dougie
I do see where you are coming from but we really cannot give you verbatim diagnostics, only a gentle nudge and help. If the fault, as in your case seems to be getting very technical, ie meter,leakage testing etc then specialist equipment and knowledge would be needed hence DPs and my suggestion of an engineer.As far as a replacement, Bosch have a very good reputation and are sensibly priced, as are the spares.
April 4, 2007 at 5:11 pm #186664dougiex
Finally after leaving the machine untouched for long time, I have got round to removing the pump (Askoll). Noticed on doing so that the larger hose is split almost half way round. Looks like this could account for tripping RCD (connector possibly getting wet), and all water being pumped out of hose. Am I right to think that the hose cannot be purchased on its own, and that I would have to buy the whole pump assembly? (4812 361 58334 I believe). Also, are the removed jubilee clips reusable? Thanks in advance, Dougie.
April 4, 2007 at 6:26 pm #186665Penguin45
http://www.ukwhitegoods.co.uk/modules.p … cts_id=653
Is what you want. It appears to include new clips. These “crimp” into place. I find internal circlip pliers do the job for me.
April 4, 2007 at 10:18 pm #186666dougiex
Is the new pump is an improved version/different make? Thanks for your prompt reply
April 5, 2007 at 12:00 am #186667Penguin45
Sorry – had assumed you’d read this:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159Penguin45.
April 17, 2007 at 8:22 pm #186668dougiex
Received new pump and was a bit concerned as it had an L shaped bracket to fix onto the chassis of machine (original had spindle and rubber grommet). Needn’t have worried as obviously Diplomat were aware of the pump problem as there were holes and slots in chassis already to accommodate new pump. Many thanks to all, dishwasher now up and running (should keep missus happy for an hour or so).
