diplomat adp8322 – water logged
Home Forums Public Support Forums Help And Support Dishwasher Help Forum diplomat adp8322 – water logged
  • #16305
    apollo30
    program stops mid cycle. have cleaned filter, and reset program, manually scooped out water but same thing keeps happening.
    any help to resolve problem? 😕
    #169212
    Re: diplomat adp8322 – water logged
    This is a Whirlpool made appliance. Check when the programme stops whether or not the lamp is flashing. If it is, it will be in a pattern, ie 1-2-3 pause, repeat. This is an error code, which can help identify the problem; although my first thought would be that the machine is not draining. Check sink coupling for blockages and drain hose for kinks. Beyond that the drain pump itself may be blocked, which entails a fair amount of demolition to access it.
    Click the link below for pro help if you are unsure, power off at all times if you are going to investigate further.
    gegsy
    Does the START lamp flash a certain amount of times? If so how many?
    :wave:
    Evenin’ Gegsy……..
    P45.
    #169215
    apollo30
    thanks guys. the error flashing is – 1,2,3,4,pause, then this repeats
    does that help identify the problem
    #169216
    gegsy
    Hya Chris :wave:
    Fault 4, thus it would be a drain failure.
    So you will have to check for kinked pipes etc. If all that checks out It looking liek aweak drain pump.
    apollo30
    thanks for all the help and replies. problem was just a kink in the pipes which is now fixed. thanks again
