diplomat adp8332
  • #35382
    miranda
    Hi, my dishwasher which is now 2 years old has stopped cleaning ie, does not clean top shelve. No fault codes present, machine completes its cycle, heats up the water and pumps out ok but leaves dishes dirty . Howdens want £90 call out charge plus parts and labour! Any advice on DIY ? Miranda
    #246350
    Re: diplomat adp8332
    1/ Rotor tips choked.
    2/ Check that feed tubes to upper rotor are plugged in behind bottom rotor.
    3/ If above not applicable, you’d better have aread of this ARTICLE.
    miranda
    Thanks for the advice . Tried everything, nothing chocked, no funny sounds, everything normal apart from when i put say a soup plate in the top shelve start a run there is no water in the plate at any time during the cycle. Does this mean a new pump? Rgds Miranda Ps everything including the electrics are in A1 condition
    #246352
    I can’t give you a definitive answer to the question. The circulation pump is the known weak spot on these machines, however a blockage underneath can give similar problems – only two weeks ago I dealt with a similar problem which turned out to be a plastic medicine spoon blocking the inlet to the heater.
    You’re cheapest option would be to use the repairs@ link below to find a local UKW independent engineer in your area – our charges are considerably lower than the manufacturers.
    Let us know how you get on,
    miranda
    It annoyed me so much that i decided to remove the pump myself! However i cannot decide how to remove the jubilee type clips ,do i need to purchase a special tool as i might just be able to remove them but probably not be able to put them back on.Rgds
    #246354
    miranda
    Just a quick thankyou for your invaluable help. When i removed the pump a small piece of broken glass was stuck in the impeller!! So now its working better than before,so thanks again.Rgds Miranda
