Diplomat ADP8332
  • #47582
    johnnyj
    Been at a Diplomat ADP8332 dishwasher coming up with FA error code, am i right in thinking it is the pressure switch/sensor thats at fault.
    #293883
    martinm
    Re: Diplomat ADP8332
    i’d check its not syphoning first they are prone to syphoning if hose is pushed to far into standpipe
    #293884
    A1engineer
    fa fault or 11 flashes Optical water indicator, use a tooth brush and clean the black grid thing that sits in the sump, if its really bad you can twist it out and clean it that way.
    #293885
    johnnyj
    I’ve tried the toothbrush but still doing it, i’ll order one up and see if that cures thanks guys JJ
    #293886
    cornwell40
    Had one of these yesterday.
    Ended up being a write off, as the circ pump rubber hose had been leaking :rolls: and been spraying over the heater for a while causing it to short to earth.
    Motor, heater and a possible board fault as it was also giving F1 code intermittently 🙁 .
    Usually a toothbrush job though 😉
    TC
